Help Center> > FAQs> Connection and Access FAQs> What Should I Do If a Database Client Problem Causes a Connection Failure?
Updated at: Mar 29, 2019 17:00
Identify a DDS DB instance connection failure caused by a client problem from the following aspects.
  1. ECS Security Policy
    In Windows, check whether the DDS port is enabled in the Windows security policy.
    In Linux, run the iptables command to check whether the DDS port is enabled in firewall settings.
  2. Application Configuration
    Check whether the IP address, port parameter, and Java database connectivity (JDBC) are configured correctly.
If the problem persists, contact post-sales technical support.
Did you find this page helpful?
Submit successfully!
Thank you for your feedback. Your feedback helps make our documentation better.
Failed to submit the feedback. Please try again later.
Which of the following issues have you encountered?
Please complete at least one feedback item.
Content most length 200 character
Content is empty.
OK Cancel
