Help Center> > User Guide> Blockchain Management> Block Browser
Block Browser
Updated at: Jun 19, 2019 17:02
You can query blockchain information required for maintenance, including the block quantity, transaction quantity, block details, transaction details, performance, and peer statuses.
  1. Open the block browser page.
    1. Log in to the BCS console.
    2. Click Manage Chaincode & Block in the Operation column of the service list.
    3. Enter the username, password, and verification code, and click Login.
    4. Choose Block Browser in the navigation tree on the left.
  2. Select a channel from the Channel drop-down list box. Real-time data is displayed in the lower part of the page.
  3. You can view the following data in the block browser.
    Table 1 Data
    Item
    Peers
    Number of peers in the selected channel
    Chaincodes
    Number of chaincodes in the selected channel, that is, the number of the chaincode versions
    Blocks
    Number of generated blocks
    Transactions
    Number of transactions that have been performed
    Block details
    • Click Last 10 Blocks to view the detailed information about the latest 10 blocks, such as the block hash, data hash, and creation time.
    • Click View more in the upper right corner of the table to learn details about more blocks.
    Transaction details
    • Click Last 10 Transactions to view the information about the last 10 transactions such as the transaction IDs, creators' MSPs, and creation time.
    • Click View Details in the Operation column of the transaction list to view more details about the transaction.
    • Click View more in the upper right corner of the table to view details about more transactions.
    Performance analysis
    The line charts show the trends of performance data, helping you know the performance status.
    • Block performance: Click Block to view changes in the block quantity. Move the pointer along the curve to view the number of blocks at different time points.
    • Transaction performance: Click Transaction to view changes in the transaction quantity. Move the pointer along the curve to view the number of transactions at different time points.
    You can select a time granularity (hours or minutes) in the upper right corner of the chart.
    Transaction quantity of organizations
    The pie chart shows the percentage of each organization's transactions.
    Move the pointer on the pie chart to view the transaction quantity and percentage of each organization.
    Peer status
    You can view the running statuses of all peers in the selected channel to detect exceptions of peers in time.
Did you find this page helpful?
Submit successfully!
Thank you for your feedback. Your feedback helps make our documentation better.
Failed to submit the feedback. Please try again later.
Which of the following issues have you encountered?
Please complete at least one feedback item.
Content most length 200 character
Content is empty.
OK Cancel
