Help Center> > User Guide> Overview> What Is DCC?
What Is DCC?
Updated at: 2018-11-07 21:12
Dedicated Computing Cluster (DCC) provides dedicated, physically isolated computing resource pools on HUAWEI CLOUD, allowing you to use physical computing devices and resources exclusively. DCCs must be used in DeCs. So, you need to apply for a DeC before using your DCCs. Then you can centrally manage your DCCs in the DeC.
Did you find this page helpful?
Submit successfully!
Thank you for your feedback. Your feedback helps make our documentation better.
Failed to submit the feedback. Please try again later.
Which of the following issues have you encountered?
Please complete at least one feedback item.
Content most length 100 character
Content is empty.
OK Cancel
