Expanding a DESS Device
If the capacity of your DESS device is insufficient, you can expand it.
Context
For details about the capacity expansion of DESS device, see the following table.
Table 1 Description of capacity expansion of DESS device
Type
Common I/O, common I/O (low latency)
  • The capacity of a DESS device can be expanded only when the device is in the Available state and the device capacity you have applied for does not reach the maximum capacity - 100 TB.
  • The initial capacity of a DESS device is as follows:
    • 10 TB: Capacity expansion can be performed once after capacity expansion to 20 TB. The capacity expansion specification is 20 TB.
    • Other capacity: Only one capacity expansion is supported, and the capacity expansion specification is 20 TB.
High I/O, high I/O (low latency)
  • Only one capacity expansion is supported, and the capacity expansion specification is 20 TB.
Ultra-high I/O, ultra-high I/O (low latency)
    • 10 TB: Capacity expansion can be performed multiple times after capacity expansion to 20 TB. The subsequent capacity expansion specifications are 20 TB, 40 TB, 60 TB, and 80 TB.
    • Other capacity: Capacity expansion can be performed for multiple times. The capacity expansion specifications are 20 TB, 40 TB, 60 TB, and 80 TB.
  1. Log in to the management console. For details, see Logging In to the Management Console.
  1. Click and select the wanted region.
  2. Click and choose Dedicated Cloud > Dedicated Enterprise Storage to go to the DeC management console.
  1. On the navigation pane on the left, choose Dedicated Enterprise Storage > DESS Devices to go to the DESS device list page.
  2. Click Expand in the row of the wanted DESS device. The Expand dialog box is displayed.
  3. Select the capacity to be added.
    The total capacity must be 100 TB or less after expansion.
  4. Click Apply Now.
  5. Confirm the order information and click Submit.
Follow-Up Procedure
After submitting an order, in the upper right corner on the DESS home page, choose Fees > My Orders and click Details to view the order details.
For details about the DESS device capacity expansion order status, see Table 2.
Table 2 Order status description
Status
Pending Approval
Your order is in the Pending Approval state as soon as you submit the order.
Pending
The system administrator approves the order within three days. After the approval, the order status changes to Pending.
Processing
You can click Pay to pay for the order. After the payment, the order status changes to Processing.
Completed
The O&M personnel, after being notified, expands the capacity of the DESS device. When the order status changes to Completed, the capacity is successfully expanded.
